Top Surface Line Width
Pridanc
Go to solution Solved by GregValiant,
Posted · Top Surface Line Width
Folks, as you can see I have the Top Surface Line Width choice checked but when I'm in the slicer under Top/Bottom, that choice is not there.
5.4.0   I've no doubt I've goofed something up but any thoughts and I'll make the change!  All the best and TY, PDC
    • Solution
    The "Top Surface Skin Layers" must be > 0 and the "Top Layers" must be > 0.
    Pretty much everything is in "fdmprinter.def.json".
    "roofing_line_width":
                                "label": "Top Surface Skin Line Width",
                                "enabled": "roofing_layer_count > 0 and top_layers > 0"
        • 27 replies
