now do you move the preview down the screen on a windows laptop with no mouse?
Posted
· now do you move the preview down the screen on a windows laptop with no mouse?
You have a track pad?
I think your only option is zoom in/zoom out which is + and - keys. "=" key also works as zoom out. You might have to click once on the preview area.
What you want it usually called "pan". with a mouse, to pan you click and drag middle mouse button OR you shift click and drag right mosue button.
ALSO!
Some windows track pads allow you to do right click drag. To left click drag you tap twice but on the second tap you start dragging. But for right click dragging you do the same thing but with 2 fingers. Do that with also the shift key down and pan might work. You probably have to enable "gestures" in windows before this works. Search for "gestures" after clicking the windows key.
Also you can "orbit" with the arrow keys. You probably already discovered this.
Also with CTRL/+ and - you can go up and down the layers to see each layer.
Posted
Some trackpads also allow you to do click and drag gestures by holding down in the bottom left or bottom right corner (depending on which button you want) and moving another finger across the pad.
1
gr5 2,196
ALSO!
Slashee_the_Cow 353
