Are the fumes from the melting PLA harmful?
PLA doesn't make much/any fumes, and they are not harmful (AFAIK).
If you see any fumes, it is most likely water steam. The PLA is hygroscopic, and the water bubbles out during printing, causing all sorts of little surface imperfections. best to keep the PLA in sealed bags with desiccant.
Daid 304
I don't think they are. But you might want to lower the printing temperature, you get less fumes that way. Printing at 250C gives a lot of fumes, while printing at 220C gives a slight smell after a hour or so.
