Not all ABS is created equally (really!), so this is hard to say. (Color) additives may play a big role. UV light is also not the only enemy; 3d printed objects can have many nooks and crannies where moisture can build up and either create a nice atmosphere for algae and moss, which may speed up deterioration, or which will lead to mechanical stress when temperatures go below 0.
ABS isn't a good choice for outdoor. UV and weather resistance it is not good in general. Better alternatives for this use case are PETG and ASA. For printing ASA you need a well vented Room as the fumes are not healthy (same as for ABS). I usually print this material outside with an enclosed printer.
Making prints for outside you should take the color of a print as well in consideration. Dark colors have a higher heat absorption then bright colors. Most of the time I choose PETG because easier to print end its better flexibility is often a plus. ASA is more temperature resistent and is from its mechanical properties more close to ABS. You can smooth out surfaces easily with vaporized acetone if needed.
ahoeben 1,950
Edited by ahoebenLink to post
DivingDuck 104
