Yep I already did that. If you check my 3mf file I already have a script there. The problem is that the Tina won't resume again after the pause.
Note, it resumes fine I pause it manually on the printer itself. But it's just a bother having to watch for the right place to pause and would be pretty impossible to do on more complex multi-color designs.
Edited by jetfire158
Slashee_the_Cow 619
You could try using this post-processing script by the awesome @GregValiant. Just one of his many fine works.
To install post-processing scripts, go to your Cura configuration folder (in Cura, go to Help > Show Configuration Folder) and put the .py file in the "scripts" subfolder. Then close and reopen Cura, go to Extensions > Post Processing > Modify G-Code, that'll bring up a window, click Add a Script and select the right script from the dropdown, then fill in the options on the right hand side... his scripts usually have no shortage of options.
(Sorry if you already know this, but I figure people who know what they're doing can just cruise over it, and if someone doesn't know the process then they don't have to reply asking for instructions)
PauseAtHeight.zip
