CC 0.6 works fine with any material. Make sure "line width" is set to 0.6 in the profiles (it should be). Worst case you can use an AA 0.4 profile, change line width to 0.6 (change nothing else) and when it complains that you have the wrong core just click "ignore".
gr5 2,176
Write to sales@3dsolex.com. Tell them you are in Turkey. They have these parts. They are the 2 most expensive parts on the core. Roughly 20 euros each. Are you sure the heater is broken also? The heater is tougher than the sensor. The heater should be around 25W so around 24 ohms (power=24*24/resistance). The sensor is much more delicate. It should be around 109 ohms at room temperature.
Solder can not be used to make these parts because solder melts at a temperature below printing temperatures.
I forget the diameters but the are integral amounts of mm. For example 3mm and 4mm? Not 3.1mm or 2.9mm. No fractions.
parmaksizfurkan 0
Thanks for u reply. So can i do abs print with CC core ? Is this a possible or healthy method ?
