About the only conceivable way I can think of doing it in Cura which might work would require making a plugin that allows you to manually (no way to do automatically) stop a USB print and move to the next model, but such a plugin would be complicated and USB printing receives little attention because it's mostly a legacy feature which is mostly unused (because it's a lot less reliable than putting your g-code on an SD card or whatever input your printer takes).
There's no way to do it in g-code, so it's not possible while slicing or in a post-processing script.
Automatically doing it by connected camera in OctoPrint or firmware: theoretically possible but a lot harder than it sounds. You'd need to use some sort of AI image processing to detect a print failing, compared to a pre-generated render of what it should look like at every stage, which is extremely computationally expensive..
Slashee_the_Cow 382
Not possible in Cura as it is.
ahoeben 1,968
See this OctoPrint plugin for example:
https://github.com/paukstelis/OctoPrint-Cancelobject
Mephisztoe 0
I believe the CancelObject Plugin for OctoPrint is something, I will have a look at. Sounds promising!
