7 hours ago, GregValiant said:If there are M109 temperature commands (likely) in the gcode then that will usually cause a delay before printing resumes. If both cores are printing at the same temperature, and if the stand-by temperature for both cores is the same as the printing temperature, then you could (if you are brave) use Search and Replace to change all the "M109" lines to "M104"'s.
BUT...If the temperatures are not the same, then you need to let the printer adjust temperatures and that will mean a short wait every time there is a tool change.
Yes i figured something like this was the reason, however I thought that the temperature was adjusted to the correct level while the opposite core was finishing its layer so that it was ready by the time the cores switch?
GregValiant 1,261
