I have a couple of questions to narrow it down.
- Do you have multiple monitors? Does Cura start if you disable one of the monitors?
- Do you have two monitors placed above each other? Can you try this workaround from the community? https://community.ultimaker.com/topic/42633-cura-522-stopped-working/#comment-318105
- Do you have GPU Tweak OSD overlay enabled? Does Cura start if you disable that software?
- Do you have a Ryzen Graphics card? Can you try this workaround? https://support.makerbot.com/s/article/1667412437627
- Do you have the Nahimic audio enhancement service enabled? Can you try this workaround? https://github.com/Ultimaker/Cura/issues/12102#issuecomment-1157907665
- If your problem is related to scaling, can you try this workaround from the community? https://community.ultimaker.com/topic/41458-ultimaker-cura-510-window-scaling-problem/#comment-311838
- Are you the Administrator on your device? Could you try to right-click the shortcut and "Run as administrator"?
1
Slashee_the_Cow 382
Could you please upload your cura.log file? In Windows you'll find it in %APPDATA%\cura\5.4\
