I noticed this too dokcal. I tried to slice this item: https://www.printables.com/model/554709-nasa-fabric/files. It was the 12x16 size and it took about two hours to slice. I've done bigger and more complex prints and I've never had it take more 5-10 mins. This was also when I was using version 5.4. There has to be some new issue with this new software version. I'm going to try some things on 5.4 tonight and tomorrow to see if I get the same delay/stall again.
1
Slashee_the_Cow 321
No changes that I'm aware of. Seems about as quick as 5.4 to me. Could depend on your system and printer (like I'm guessing it takes more time for an Ultimaker S series since they figured out how to make it print faster).
I have experienced a couple of times when it stalls and never finishes, for those I had to switch from tree supports to regular and then it sliced fine.
Edited by Slashee_the_CowLink to post
