After you upgrade the hardware, you need to upgrade the firmware to the "plus" version. That's all there is to it.
thank you! an additional problem was not the native wire from the printer. the wire connecting the computer and the printer via USB.
use the included firmware and the firmware was successful. thank you!
2
gr5 2,178
You are doing fine.
ultiKOS 2
