Hi aheben,
Thank you for your help.
However, I moved the model and I have the same result :-/
NB : The "slicing failed with an unexpected error" does not occur if I try to slice on another printer. For example, I tried the FLSUN Super Racer and it works well.
I tried to change the configuration of the extruder but I don't knwo what to change. I saw I have a Nozzle Size to empty on the top bar but I don't knwo where to configure it (there is not such parameter in the Printer or V400 Hotend menus).
I must have forgetten something but I don't know what.
ahoeben 1,949
The two messages are unrelated.
The "there are no profiles matching the configuration of this extruder" can probably be fixed by clicking the Extruder icon in the top bar and changing its configuration.
The "slicing failed with an unexpected error" is a Cura bug, and can often be remedied by moving the model to another location on the buildplate or rotating the model.
