Thank you for your help unfortunately the orientation does not change the behavior i always get the z-seam at my pocket...
A workaround for this problem is to use two separate models, one inner model and one outer "shell" which is only one line thickness thick. But this is VERY inconvenient! And even if i do it that way, the speed of the print is changing at the pocket location. If i just print the outer shell alone, i do not get any change in the printing speed and i get a consistent wall.
Halter_Lichterkette-Körper.stl Halter_Lichterkette-Körper001.stl AI3MSPRO_Halter_Lichterkette-Körper.3mf
GregValiant 1,261
The geometry of the model dictates that there will be a seam for that pocket.
With the model at the midpoint of the Cura build plate, set the "Z-Seam Alignment" to "User Specified" and the "Z-Seam Position" to "Back Left".
Here is how I oriented the model in Cura.
If you place the model differently then the "Back Left" would change.
Edited by GregValiantLink to post
