Hi @neillymackers,
This is actually a "print mode" (surface mode) I'm often using.
The only way to improve layer bonding in this mode are by reducing layer height.
You can use, say layer height is 0.1 mm, then go to experimental mode and select "use adaptive layer".
Then Cura will reduce layer height in order to make gap/climbing wall printable. This mode reduce print time, but surface finish may suffer somehow. Use Cura "Preview" to inspect your settings, oh., yes I'm using Cura 4.13.1 for RC printing.
Skipping the use of "use adaptive layer" will give better overall surface, but will reduce the "sealing" quality of a climbing wall. Sure, this are a little about give and take -but it's your decision that counts. 🙂
I often use this approach for faster appearance checking of all types of models/projects -if this mode is possible to use.
Good luck
Thanks
Torgeir
Slashee_the_Cow 272
If you could the Cura project file (.3mf, in Cura go to File > Save Project) that would really help us to diagnose the problem.
There's about one thing that comes to mind immediately when seeing that sort of picture but I'm pretty sure the answer is no anyway: you don't have adaptive layers on, do you?
