GregValiant 1,258
Thanks for that, so the cause for the problems is just the bottom layers not being even?
GregValiant 1,258
Not just that. There is a flaw in the model that is causing Cura to ignore the lower layers.
This is from formware.co/onlinestlrepair
-> Analysed your file:
--> 236 Naked edges (?)
--> 2 Planar holes (?)
--> 0 Non-planar holes (?)
--> 116 Non-manifold edges (?)
--> 172 Inverted faces (?)
--> 0 Degenerate faces (?)
--> 2 Duplicate faces (?)
--> 0 Disjoint shells (?)
That's a fair number of errors in a small non-organically shaped model. It's the "duplicate" and "inverted" faces that are causing the problem. The non-manifold edges aren't helping.
Edited by GregValiantOh dear, need to work on my blender skills then? Thanks
1 hour ago, Fearn said:Oh dear, need to work on my blender skills then? Thanks
Maybe a bit your skills problem (if there are naked edges and holes), but also a "Blender isn't great at outputting models for 3D printing" thing. I'm not saying don't use it, just that it's a lot easier to convert your average CAD file to an STL model than a mesh like Blender uses.
If you're using Windows, the Microsoft "3D Builder" program is actually really great at fixing broken models. It can't perform miracles, but if I import something into Cura and get errors then I get 3D Builder to fix it, when I load it in Cura again, no issues.
obewan 37
You will need to attach the stl or even better a cura project file
