fbrc8-erin 273
It seems like possibly your side fans might not be running in the first photo. Also, when was the Z-screw last cleaned and lubricated? The Z-shafts?
+1 for checking the side fans, debris like a loose chunk of support structure can get in there and jam them up. The printers can't report if the fans are actually running properly so you need to visually check.
mamastoast 0
A lil more information. This printer has previously printed spheres with very few issues. I dunno why it's decided to mess up at even small overhang angles.
I've tightened the belts on the printer(one was a lil loose, but fixing it didnt make a difference)
I've calibrated XY
I've tried printing at 190
I've cleaned the print core
I'm printing at 100% fan speed, PLA filament, entirely new spool.
I've tried printing at different layer height and speeds, doesn't seem to make a difference.
Tried printing upside down with supports, there is a distinct "stepping" going on
Edited by mamastoast
