Posted · Can't "Move Material" U2
When I go to "Move Material" in the maintenance menu, the temperature goes up to 210 (PLA) and says to turn the wheel to move material. But when I turn the wheel nothing happens. No sounds or motion form the extruder motor.
Help?
    Connect to printer over USB from computer running latest version of Cura, and then select the firmware install menu option.
    Thanks. I did that, but still cannot move material!
    This is still happening to me a bit. I found I really have to yank on the material sometimes to get it out, then the extruder motor seems to grab and start turning again.
