gaps in top layer
Electricfuse
Posted · gaps in top layer
8 minutes ago, Electricfuse said:
Ok, I had 10% infill, but print called for 0.
That's a great recipe for a print to fail. Or get destroyed if you accidentally knock it over.
Could also be worth considering the infill pattern: if you don't particularly need strength, zigzag is a great infill pattern to use to in this sort of case because (along with grid, but printing zigzag is better because it requires fewer retractions) it has the infill lines closest together, meaning the top is supported much better.
