The problem doesn't just lie with Cura, but the Qt widget toolkit it uses, so it might be properly fixed until (if) patches come from upstream.
Anyway, to try and get Cura running again:
Go to %APPDATA\cura\5.6\ (or whatever version you're using)
Open cura.cfg (notepad will do)
In the [general] section at the top, delete the lines that start with window (they hold the position, size and state it was in and can get messed up with multiple monitors)
Disable all but your main monitor (just temporary, we want to do all we can make sure Cura loads)
Open Cura
Go to Preferences > Configure Cura
In General (the default pane when it opens), under Viewport Settings turn offRestore window position at start
Close Cura, re-enable your extra monitors.
Make an offering to the display gods, and hope that Cura will open reliably in the future.
Slashee_the_Cow 319
