Very nice work! Did you do the changes (direct drive, GT2 belts) all at once or one after the other. In other words, can you guess how much improvement came from the direct drive and how much from the GT2 belts? I currently have a direct drive but still the original MVL belts.
I guess the circles are about 1-3/10 to small, aren't they? It's a question of shrinkage of the PLA. You have to correct in the model. As you do in injection moulding.
btw: are you not afraid that the PSU of your heated bed radiates a bit too much a the PLA gets soft on the spool? Or is it not PLA?
Thanks,
I did all the changes at once. The pulleys on the UM i received were not reaching for high precision... so I bought the GT2 instead. In the old config I printed the rest of the parts and then I started the rebuilding.
The PLA will not get affected by the PSU. It leaves very little heat and as I have mounted it vertically the excess will not pass the PLA in high degree. If I would consider the PLA being affected it will not result more than tops 1/2 degree.. Nothing to worry about.
The next step is to modify the tension devices a bit. I'm thinking of making one of the sides fixed and just one being used for tension. The only drawback from this is that it will be slightly more difficult to mount the belt. Or - I will just change the holding mechanism so the they are straitened out more and so that I perhaps do not need the clips over the belt. However, the clips works fine..
One thing I'm curious about is how come the holes are affected and not the whole part? If the PLA shrinks all of the part should shrink. Now the outer measurements fits perfect but the holes do not. 1+1 does not add up here... or have I missed something?
Dim3nsioneer 556
