Apart from that plugin, there's also the option to turn off the prefix altogether in the General preferences inside Cura: "Add machine prefix to job name"
2
DivingDuck 105
There is a plugin for manipulating print job names called Printjob Naming. Maybe you had use that some when and then forgot about it?
