Thank you for the feedback.
I was running another print of the card holder after applying the Retraction settings. Things became so much more obvious on a larger scale when the print actually finished going through all the layers.
Now there's value in what I just learned from this failed print - I had inadvertently left my infill at 0.00%. All four corner columns are merely the shell - a 0.4 mm wall. The good news from this completed print, I know for a fact my gears are 100% calibrated because the nozzle lined up perfectly with the previous layer for at least 50mm of Z travel. 😉
I also found I had a slight error/offset in my previous 10 stage tower, very minimal offset stacking the cubes in each layer. I created a new Tower to hopefully better mimic my project printing environment.
Now off to run more calibration tests with varying Retraction settings.
Thanks again for the feedback.
Slashee_the_Cow 267
Based on the pictures, the bits coming off don't look like underextrusion in the slightest, just not enough retraction (your pictures point out at low retraction distances and speeds they happen).
If it was underextruding you should be missing bits, not be getting free splinters added 😄
