That gcode section would look more like:
G1 E-2
G1 E-2 Z0.2
G1 X5 Y5
G1 Z10
Had to switch from phone to laptop to get it to format. Clearly the forum is not bbcode either. Sorry.
G1 E-2
G1 E-2 Z0.2
G1 X5 Y5
G1 Z10
6 hours ago, jaysenodell said:That gcode section would look more like:
G1 E-2 G1 E-2 Z0.2 G1 X5 Y5 G1 Z10
You forgot the G91 at the top of that. Also you're leaving speeds out of it. And I'm not sure why you'd retract twice. And moving 5mm off might not be enough.
This would be my way:
M104 S0 ; Start extruder cooling down M140 S0 ; Start bed cooling down M82 ; Relative extrusion G1 F2400 E-2 ; Retract 2mm at 40mm/s G91 ; Relative positioning G1 F2400 E-2 Z5 ; Retract a bit more and move Z up 5mm as fast as it'll go to get away from print G90 ; Absolute positioning G0 F6000 X0 Y0 ; Move nozzle to corner of plate at 100mm/s M106 S0 ; Turn off fan
Normally you might not start cooling down until the end of the gcode but we want to cool things down ASAP. This also makes it less likely to drool along the way. And it'll move to somewhere there probably isn't anything in case it's still hot or it drools.
Edited by Slashee_the_Cow3 hours ago, Slashee_the_Cow said:You forgot the G91 at the top of that. Also you're leaving speeds out of it. And I'm not sure why you'd retract twice. And moving 5mm off might not be enough.
4 hours ago, Slashee_the_Cow said:This would be my way...
That's a much more complete run at the end of print script. @kaylanichole36 you should use that if nothing else is in the field now. It may take some tweaks to be "perfect" for you but starting with Slashee's code (and the nice comments) will help you understand exactly what it happening.
ok this may sound silly but like I said I am totally new to all of this. I did find my end G-code. This is how it reads.
G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X0 Y220 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positionning
G1 X0 Y{machine_depth} ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M84 X Y E ;Disable all steppers but Z
Should I just copy and paste Slashee's into this box?
That should raise the head 10.2mm above the last position printed, then move things to align the noz to absolute 0,0 and then shut it all down.
if it isn’t doing that then either 0,0 is over the print or something odd is happening.
1 hour ago, kaylanichole36 said:G1 X0 Y220 F3000 ;Wipe out
That will make the Y axis move 220mm, which is going to sound very painful if it tries to keep moving beyond the borders of its printable area (some printers will try and blindly follow any move command they're given). Also convention says that moves that use extrusion should use G1, but travel only moves (which this is) should use G0. Technically they're both the same command but it makes for more readable code.
1 hour ago, kaylanichole36 said:G1 X0 Y{machine_depth} ;Present print
See above about G0/G1
I'd still advise putting the commands to start cooling it down at the top, just so that it starts cooling down immediately instead of waiting for all the move commands to finish just in case it dawdles a bit in the movement, especially since you're only raising it 0.2mm before you do a long (should probably be like 10-20mm instead of 220mm) travel move. Given how quickly these things don't cool down, unlikely to make a huge difference, but can't hurt.
jaysenodell 13
Hopefully others will come along and offer a better solution.
In the printer settings (Manage Printer -> Machine Settings) there is a section “End G-code”. Mine starts with
[code]
G91
G1 E-2
G1 E-2 Z0.2
G1 X5 Y5
G1 Z10
[/code]
This sequence effectively tells your printer
* work from the current point
* suck up a little filament
* suck up a little filament and lift the noz 0.2mm
* move noz x+5,y+5 mm
* move noz z+10 mm
Ideally this should be near the top of that section to make it the first thing executed.
The problem is, depending on what else is there, you may need to add additional lines after the Z move before resuming existing lines. I’m also new to 3d printing (not gcode) so let’s see if someone comes along with better advice.
Edited by jaysenodellfixed gcode interp sequence
