14 hours ago, Slashee_the_Cow said:turning on Top/Bottom > Monotonic Printing Order and Monotonic Ironing Order can help it look its smoothest
Hi I'm interested in this & was wondering where the Monotonic Ironing Order setting is? I can find the Monotonic Top/Bottom Order & Ironing settings but not the quoted setting or are they one and the same?
Slashee_the_Cow 621
It depends on a lot of things. What you're printing, what material you're printing with, your printing settings (not just ironing, things like line width, temperature, top/bottom pattern, printing order - turning on Top/Bottom > Monotonic Printing Order and Monotonic Ironing Order can help it look its smoothest, number of top/bottom layers, infill pattern and percentage), your printer, even what colour you're printing.
Plus, the fact is that with a FDM printer you will never get a perfectly smooth finish because filament is being laid in lines and layers. Commercial products use injection moulded plastic and the templates they use are completely smooth.
There's no universal "best settings" for a 3D printer, because there are always changes and tradeoffs to consider (like line width: thicker = fewer lines = fewer gaps but bigger gaps). You're best off just messing around with settings and creating small test pieces to see what works (just label your test pieces so you know which settings you were using on the one you end up liking the most).
