I'm pretty sure you can just change the feeder and motor and use UM2+ firmware and you will be fine but to be safe I would use the "tinkerGnome" firmware for the um2+ because it lets you change many more settings in case I forgot some detail and you need to change part back.
When changing to the UM2+ you definitely have to reverse the E axis and change the steps/mm to a different value. Other changes in the plus are:
fans on head different orientation
easily change nozzles on plus
higher wattage heater in print head
better teflon part (but it's the exact same shape and size - just a better type of teflon)
replaced spring with aluminum cylinder (I still like the spring better)
smaller spool holder that holds only one spool
better glass clips that are less likely to cut your fingers
So the heater is different which means the PID values for the heater are a little different in the um2+ firmware but I don't think it matters much. Worst case you will see the nozzle temperature oscillating and if so you can alter the PID values.
gr5 2,178
Tinker Marlin is here: https://github.com/tinkerGnome/Ultimaker2Marlin/releases
