You can go horizontal like this for one nozzle width as well. That's typically .4mm. And you can "bridge" across long gaps. google "3d printing bridging".
QuoteAre either of these overhangs enough to require "supports"?
The bigger overhang definitely needs supports. As you have discovered. The support only has to support the outer edge of the rim as it can bridge in between (refer to "bridge" earlier in this post).
Usually I can design the part to have 45 degree angles under the overhangs. Not always. Sometimes I flip the part over to a new orientation. Sometimes I divide the part into 2 parts and screw or glue them together.
Dustin 129
rule of thumb only 45degree anything more needs supports.. but you can go further pending your printers configuration and cooling abilities etc.
also purely flat surfaces like this yes always needs supports.
