Thanks @gr5! That makes a lot of sense, and is a very clever solution.
The hassle that I'm having now is that the AA nozzle is pushing a little too far on the rubber nozzle protector thing on the fan cover and is preventing it from closing properly.
I deduced that this is the problem because putting the AA core into the BB slot and flipping that switch allows me to clsoe the fan cover nicely (with the BB core now out of the machine entirely).
The image below (which has both AA and BB cores installed) hopefully shows you what I mean
Thanks for taking the time to help!!!
gr5 2,178
This is normal. This machine can print two different filaments. One on the left and one on the right. The problem is that the inactive print core always leaks a tiny bit. About 1mm of filament. So the printer keeps the inactive print core about 2mm above the active print core. When the right print core is in use, the right nozzle is lower. Only the right print core moves up and down. You can do this with power off by sliding the switch above the right print core towards or away from you. It's okay to leave the print head in either state as when it powers up it will move the right core to a known state.
