11 hours ago, GregValiant said:I'd go with a 0.6 nozzle at 0.3 layer height and 75mm/sec.
I recenlty tried this as a general "I'm tired of waiting" fix. Keep your lay height under 0.38 and you're good (I didn't beieve the math from Prussa to tried it... don't waste the filiament). For the most part you can't tell the diffence between 0.4 and 0.6 nozzles. There is some loss in edge detail and "fine line" but nothing I considered critical for strucural work.
Edited by jaysenodell
GregValiant 1,253
Your printer settings are for a 0.2 nozzle at 0.2 line width and 0.12 layer height. That will make it a 16 hour print and a 19mb gcode file 613,000 lines long.
If you are printing that with a 0.4 nozzle installed in the printer then it will be severely under-extruded.
With a regular 0.4 nozzle, 0.4 line width, and 0.2 layer height it's a 5hr print time and an 11mb file of 352,000 lines. Big difference there.
It's a simple model. I'd go with a 0.6 nozzle at 0.3 layer height and 75mm/sec. That knocks the print time down to 3 hours. You can push a 0.4 nozzle to .6 line width but it would be better to have a .6 nozzle installed in the printer.
