The yellow isn't actually a border - it's skin (top/bottom layers). If you could post the .3mf file for your project (get it ready to print, then go to File > Save Project) there might be something in there that can help.
Important heads up though: Once you get past the first layers, printing that fast requires specially designed filament. You can't do it with regular filament. Right click on Print Speed and click Use value from material and it will set it to the appropriate speed for that filament. I would also turn down the acceleration (let me guess, you have an Ender-3 V3 KE?) because my E3V3SE can accelerate at up to 4000mm/s² but when it does that it can actually pull parts of the model with it, deforming the whole thing. I set it to 500mm/s² (and what I've read says sometimes you have to change it in the settings on the printer's screen or it'll just ignore the speed in the gcode and travel that fast anyway). Changing the acceleration shouldn't make a huge difference in time, but remember, slow good print > quick bad print.
Slashee_the_Cow 337
