45 minutes ago, Slashee_the_Cow said:ty for your answer: So,I apologize for the size of the text, and for fear of not being understood by you I used the Google translator (I'm Italian) but I can't make the text smaller. I'll try to write directly here
1) importing print profiles; given that on cura 3.6 I can import them without problems and they work, with another versions, for example 5.5.0 it gives me the following error: "PETG profile MY GOOD, imported correctly.
Warning: The profile is not visible because the draft quality type is not available for the current configuration. Navigate to the material/nozzle combination that allows you to use this
kind of quality."
2) Printer Creality ender 3, it was already present in previous versions, and was also already included in version 5.0
3) you can see the available profiles in the attached photo.
At the end of everything, the profiles are imported, but it doesn't let me see them and consequently I can't use them. damn!
Slashee_the_Cow 303
*/me sighs* They really need to disable being able to paste rich text into a post. We can read your message fine if you use the same text size as everyone else. Please just type in the text box on the web page.
As for your problems: Cura 3.5 and 3.6 are over five years old. They've been out of official support for years, and them working on current versions of operating systems is in no way guaranteed. If you run Windows, you could try running it in compatibility mode, but there's no guarantee that'll change anything.
As for importing your print profiles: we'd need a bunch more information. For starters, what is the specific error you're getting? What printer are you using? Was its definition included in 3.5 and 3.6 or did you have to add it yourself (and if so, is it included in the 5.x series)? If you could post the profiles (they're in the quality_changes subfolder in the Cura configuration folder) that might help.
