1 hour ago, Zlutz said:Found one more peculiarity on the other file, could be the same thing? Is this not a bug but a feature?
Shouldn't there be yellow under every green and red?
Well other green and red is acceptable under green and red 😄. But no, it's entirely normal, some things don't need skin, especially if they're internal.
Any chance you could post it as a Cura project file (.3mf, in Cura get it ready then go to File > Save Project) instead of the STL and profile separately? It's a lot easier to work with and also includes your printer configuration (which probably wouldn't affect it, but you never know).
Zlutz 0
Slicer is doing the green lines directly on the infill... maybe there's a setting I should turn on/off?
Edited for clarity
