I know this isn't an thing most folks want to to, but if you build from souce...
Basically, Cura as an open source project, you are able to download the sourcecode, find the place where it loads the image, comment that line of code out, execute the config comand followed by the build and it won't be able to load the image.
I would suggest that not havig a slapsh screen is a good way to wind up with a pile of "not loading" issues as you can't see if the code is executing on start up or not. If you like launching from shells with logging into stdout then no stratup screen makes sense to me. otherwise it's a UX no no.
Slashee_the_Cow 280
Unfortunately I'm not sure there is a way using the AppImage (since you can't edit it). Playing around I found you can do it by renaming (or deleting) C:\Program Files\UltiMaker Cura 5.6.0\share\cura\resources\images\cura.png on Windows. Excuse me while I go make a picture of pixel art cows in a paddock to replace it with.
As far as I'm aware there aren't any command line options for Cura (running either the binary in Windows or the AppImage in Linux. You could submit a feature request though.
I've yet to find a distro with an up to date version in its repos. My beloved OpenSUSE Tumbleweed is only up to 4.13.0 😕
