So here,s project file. .
I refering that (at least in my case) cura generates strange layer that have many lines.
First layer is ok:
then second one generates like this:
in vase mode i've set bottom layers to 3.
But if set them to 4 then 4th layer is strange again:
and that behavior is only in vase mode.
Slashee_the_Cow 271
If you could share the Cura project file (.3mf, in Cura get it ready to go then select File > Save Project) that would really help since it's hard to tell just based on one screenshot.
Looking at that one one screenshot through: spiralise mode uses as many bottom layers as you have selected before it starts spiralising and that looks like it could be skin so try going to Top/Bottom > Top/Bottom Thickness > Bottom Layers and setting it to 1. If it is bottom layers and you want it to look a bit more appealing try setting Top/Bottom > Top/Bottom Pattern to Concentric.
Edited by Slashee_the_CowLink to post
