With that in mind, and knowing that I'm happy to start the first 10mm or so with the "stock" setting of 100% flow, I wanted the first change to happen at layer 30 and that change would be to 105% from 100, and then to change every 25 layers by 5% each time. Do you feel, after looking at the picture above, that this is what I achieved in the settings I gave the Post Processing Script? The final test print sure looks like it but I've fooled myself before.
I haven't used that script but it looks like you got the settings right.
8 hours ago, Pridanc said:
If I started my test print at 100% flow, and after looking at the test when finished and find that I like the flow of 120%, is 120% the number I go back into CURA and insert 120 under flow when printing this material?
Yep! Just change it in Material > Flow and make sure to click the save button at the top right of the settings.
Slashee_the_Cow 295
