Thanks for your reply, that's a great tip.
Good points on the density, I was really struggling with that and your infill analogy makes a lot of sense.
Yes, silk materials aren't my favorite, I find the overhangs are awful and it's a very gummy material to remove supports from. Hotter is an interesting idea
So to recap -
The support z distance question is still not clear. Maybe same as layer resolution?
Support Density 33%
Change Support > Rest Preference to On buildplate when possible.
Slashee_the_Cow 270
One change I always make when using trees: change Support > Rest Preference to On buildplate when possible. It's one of the most overlooked settings but it makes it place the trunks on the build plate (where possible) instead of on your model, so you don't have nearly as much floor to clean up.
It's really something that requires testing based on your printer, filament, models, etc. Usually it's a multiple of your layer height (or Cura will likely round it to be, IIRC). You can get away with a bit bigger with materials like PLA because it's a lot like bridging except you're going over something (it sets fairly quickly before it has a chance to droop), I use two layer heights, although stuff like the silky PLA tends not to do as well (hint: run it about 5° hotter than other PLA).
With materials which are lot more likely to droop and sag (like PETG and TPU) I use one, better a model with a bit of support stuck to it than a model with a big saggy bit, although it's annoying with TPU because (be careful kids!) it's so soft you can't really cut it with a knife, you have to find a serrated blade.
I think your support interface density is too high. It's sort of like placing things over infill - you don't need infill density that high for stuff to successfully go over it, and with your support interface it means there's more to stick to it. I use between 20% and ⅓, depending on the project and material.
As for pattern - basically the thing is that with with lower support interface densities, depending on what's above it, you have to worry about gaps. With diagonal lines above it it's fine:
But if for whatever reason you have your lines running parallel to your concentric infill:
or, <insert deity here> forbid, you're using a concentric floor pattern:
there tons of gaps for your fall to floor through, whereas a pattern like grid, you never have to bridge too far:
Even if your floor is a grid and has lines running parallel to the grid lines (which by default, it will), it's still never too far before it hits some interface:
Those examples are with support interface density at 33.33333333%.
