Install the Mesh Tools plugin (from the amazingly awesome @ahoeben, who does all the plugins which seem like they should be built into Cura in the first place), then right click your model and go to Mesh Tools > Replace model (you could try Reload model but I'm not sure if it'd work in your situation) and just load your STL again.
Slashee_the_Cow 274
