It's a firmware thing, and not just yours, a deliberate choice on Creality's part. My Ender-3 V3 SE (both on stock and latest firmware) ignores speed and acceleration limits on prints from an SD card so I have to limit the speeds in the machine's firmware. Which is annoying as hell when you're using different materials (i.e. TPU likes to print reeeeeeeal slow). That's one of the reasons why I started using option B:
Printing over OctoPrint is fine because it's only getting one command at a time and doesn't know what'll be coming up so it can't try and plan ahead like that (like if you know you're going to hit a concave corner, you can't go too fast or your jerk will be way too high).
The marketing for the E3V3SE bragged about being able to print at 250mm/s and accelerate at 4000mm/s² (until the E3V3KE came out because it goes even faster). Neither of those are particularly good ideas, unless you're using high speed PLA on a printer held in suspension that will stop the large vibrations that can come with moving and turning so fast.
At default acceleration it even started pulling parts of my (PLA) model with it when it started a travel move because it just zoomed off before it had a chance to set (that's why I wrote my own post-processing script to limit acceleration while printing support (yes I know that is an option in Cura) but also on the travel moves before and after the support (which is when it was getting pulled) and Cura just uses the travel acceleration rate for those.
Edited by Slashee_the_Cow
jaysenodell 13
Are you printing from SD card or via OctoPrint?
I have the same setup and I generally print from Octo. I print with reduced rate with no issues. If you are printing from SD, I'll move one of my "reduced rate" prints to the SD and see what it does.
