7 hours ago, gr5 said:Thanx for the reply!
It only happens in this specific corner (have not tried the other corners though).
I can try to bend the heater cable during a normal print, just to see if i shorts out.
Need to find a similar Power brick though. What is the minimum spec for power rating or
what should I search for?
Yesterday I tried to park the nozzel at x=5;y=5 but same thing happend, even I had a feeling it took a litte bit longer time before the display turned off. I also tried x=10;y=10 and everything was working as it should.
Need to find the problem and fix it. Do not want to have more 3 hour prints wasted....
Regards/ Ronis
gr5 2,177
There could be a short. Does it happen often? Or just he one time? The nozzle heater cable may short out and kill power. When the head is in a corner it stresses the cable a bit and may cause a short deep inside the print head.
More likely it is the power brick.
