- 2 weeks later...
Wanted to try octoprint, yes.
but that still leaves the problem of being unclear how cura claimes or releases the usb port.
15 minutes ago, JPT58 said:that still leaves the problem of being unclear how cura claimes or releases the usb port.
Disable the USB Printing plugin (via the cogwheel icon in the Marketplace), and Cura will no longer touch your USB ports.
Which Marketplace?
Do you mean some Flatpak Management GUI?
- Solution
Ok, I tried removing "all devices" from Flatseal.
Let's see if this helps.
Seems to work.
SD and USB drives still available. SATA drives not.
and cannot connect to USB printer.
fine! Thank you very much
Edited by JPT5822 hours ago, JPT58 said:Which Marketplace?
The Marketplace button in the top-right corner of the Cura window.
Though Marketplace seems to imply that you have to pay for stuff, all of it is free, and you do not need to be logged in to an Ultimaker account to use it.
jaysenodell 37
Why not use octoprint as the serial controller?
