Thank you @Slashee_the_Cow for your input. Unfortunately, using all of these settings, either on their own or in combination with one another, did not lead to a solution. As you correctly predicted, I was only able to adjust the problematic area up or down along the model.
I prepare hundreds of small models like these for printing every week and have been searching for a solution to this problem ever since the Arachne was released, so it's been almost 2 years now. I've tried all major slicers on the market, and they all seem to have issues with printing thin lines. However, the situation is definitely better than it was pre-Arachne.
Anyway, I just hope that in a year or two, a new Cura release will magically solve this 😄 While waiting for that, I wonder if anyone would have an idea of how to somewhat adjust the slicing behavior so that the inside wall would be smoother, even at the expense of the outer wall? Essentially, 'align' the walls at the problematic area to the inside of the model so that it is smooth there, while the outside wall becomes even more rough. I wouldn't really mind that.
Slashee_the_Cow 269
The relevant settings I can think of for this are:
Walls > Wall Transitioning Filter Margin: Changes how much thinner/thicker than usual walls can before it will add (or remove) more walls, and
Walls > Minimum Wall Line Width: What it says on the box: the thinner your lines, the higher resolution you get when it comes to reducing them. Just be aware you're limited by your nozzle size on this, the general guideline is don't go below 60% of your nozzle diameter.
You may be able to use a combination of those to get a less noticeable transition (maybe set the margin to half the minimum width? I haven't tried), but unfortunately this is just one of the realities of FDM 3D printing that you can't really avoid.
It will also be affected by Experimental > Slicing Tolerance but that would likely only change where the transitions are.
Edited by Slashee_the_CowLink to post
