I'd be surprised if your printer only had a Z resolution of 0.04mm, but hey, there's a lot of printers out there and I haven't seen anywhere near all of them.
If you want to set a custom layer height (please bear in mind this is a profile for the Ender-3 V2 Neo I no longer have, so the defaults might be a bit different to yours):
In the print settings at the top right of the prepare screen, click on Custom:
Layer height should be right at the top of the list, under Quality:
You can then change it if you want:
And then save a custom profile by opening the dropdown at the top with the quality profiles:
And about the Fine quality presets: not every printer has quality presets for all of the quality settings.
Slashee_the_Cow 272
