Okay … Thanks for your suggestion, this DOES turn out to be the solution to this issue! Despite the fact that I (wrongly!) assumed the make I had was an Original, i gave it a try and just added the printer as an Original+, uodater the firnware … and … WORKS!
Thanks again for giving the solution to this, at the end simple, problem!!
- 2
ahoeben 1,951
Do you have an Ultimaker Original, or an Ultimaker Original Plus? The Original came with a wooden printhead, the one on the Original Plus came with a metal printhead. Make sure you add the proper model to your Cura, as the firmware is significantly different and gets selected by you having the active machine in Cura properly selected.
Jos_Dax 2
Thanks for your suggestion.
It is an “Original” with a heated printbed. And the printer is the same as I selected in Cura and for which I updated the firmware.
