Sorry, no log file exists in that location. Only a stdout file a folder above that with a generic message. stdout.log
Edited by snydejaThe log shows that Cura is checking to see what OpenGL versions are available (it can use either 4.1 or 2) but that the driver is responding that it only supports 1.1.
This is almost certainly a problem with the graphics drivers. Intel dropped support for them years ago and as far as I can find - and it's not easy looking, Intel don't make this easy for you, haven't released updated drivers for them in over seven years.
The latest versions of Windows 10 have almost entirely dropped support for "legacy" graphics drivers (now you have to use Microsoft's "DCH" standard), generally older drivers only run well enough to make Windows run.
You can submit a bug report but if the problem is driver related, I'm not sure if they'll be able to help you that much.
You could try this "Compatibility Pack" from intel:
https://apps.microsoft.com/detail/9nqpsl29bfff?hl=en-us&gl=US
Please tell us if that works.
If it doesn't, there's also this hack, again please let us know if that works, so we can tell other users with old hardware about it:
That is interesting since my OpenGL Extensions Viewer detects 3.1 not 1.1 and the application is only checking for either 2 or 4 not 3, so if I really have 3.1 then that might mean the problem is with the application. I will attempt the suggestions and then submit a bug report.
Edited by snydejaThe "Compatibility Pack" did not work.
If UltiMaker Cura is detecting OpenGL 1.1 then its not the software its what the driver is reporting to it.
https://support.ultimaker.com/s/article/1667410778209
This article notes minimum OpenGL of 2.0 to "run" but OpenGL 4.0+ to actually use preview mode etc.
Im wondering if this has recently changed around the time of the more recent updates.
With that said.. even if it was running with OpenGL 3.1 as you computer appears to be running.. it would still be a less than optimal experience within UltiMaker Cura
However this is the most I can come up with myself and im not a software developer and can only hypothesize.
UltiMaker does not provide formal support via the Community.
I very much recommend reporting this issue on the UltiMaker Cura github to get assistance from the software team.
https://github.com/Ultimaker/Cura/discussions
- Solution
Update! This solution worked!
https://gist.github.com/rb-dahlb/26f316c5b6089807a139fc44ee69f0d1
to install the fix named curafix.sdb copy to c:\ and run from an admin cmd prompt
sdbinst.exe -q c:\curafix.sdb
On 3/4/2024 at 3:40 PM, snydeja said:OpenGL Extensions Viewer detects 3.1 not 1.1
I think OpenGL Extensions Viewer shows what the hardware supports, from a database of known GPUs. It does not show what the driver actually supports. I could be wrong though.
Edited by ahoeben
Slashee_the_Cow 272
Please don't post a second topic with additional information. You can edit your first post.
If you could upload your log file (%APPDATA%\cura\5.6\cura.log) that could have something that might help diagnose it.
