Posted
(edited)
· Possible BUG. didn't find similar topic to this.
Well I'm a LOT younger (73) so maybe I'm mis-understanding.
When you first install a printer, you can't make any changes to the "Machine Settings" even though the dialog comes up. I'm not sure why that is. After you dismiss the dialogs then yes, you can go back through Manage Printers and make any changes.
Arc Welder is now included in Cura by default. The setting is under "Special Modes" so you need to change to the "Custom" settings to access it.
Posted
8 hours ago, Starman37121 said:
Is there a way to share an "MP4" file here. I'd like to share a rather complex build.
Only if you can fit it in a zip file under the attachment limit 🙂. You're probably better off just uploading it to YouTube and setting the visibility to "unlisted".
After a few uninstalls and re installs it still was not totally solved. I had to uninstall, then open windows administrative level and wipe out every hint that Ultimaker-Cura was ever there, then install version 5.4.0 then go through upgrades.
About the only thing you should have to delete to remove any trace of Cura (that would affect other installations) is the configuration folder, as described in this support article.
GregValiant 1,259
LePaul 322
Oh a fellow FT-5 owner, nice to see some out there printing
Slashee_the_Cow 272
