thanks slashee,
I have a ultimaker s5 with material station, should be dry from the material station.
the majority of it is printing perfect, just the starts. but maybe thats as good as it gets with TPU?
I am using a .4 nozzle, which would be better?
i do have a .6 CC
If you see the picture i attached.. you can see the far left edge is perfect
and the cura file has no starts on that edge.
and the clumping does appear to only be where starts are located.
Slashee_the_Cow 619
If you could share your Cura project file (.3mf, get it ready to print then go to File > Save Project) that would help as then we can see your print settings to see if anything stands out.
Not just each layer, after any travel move with retraction. If you turn on Travels in line type view you'll be able to see.
What size nozzle are you using? A 0.1mm layer height can be hard to pull with the 0.4mm nozzle most printers come with, especially with TPU.
I'd guess those are cases where it started and went a long distance, whereas the others, it might just be jumping from one to the next.
Some general tips for TPU (I've been printing a fair amount of it lately, because it's fun fun fun):
Any advice for your specific situation? It's always hard to tell based on screenshots (and photos), but my main suggestions would be "make sure it's dry" and "turn on expert settings and play with the Z seam settings in the Walls category". Ideally you want to have as few starts as possible, and you want them to be in the least visible locations, but it doesn't look like there's anywhere for them to go for a lot of the height of your model. You can also try lowering Travel > Retraction Minimum Travel so that it will retract even for very short moves (and it looks like that outside "folds" of your model are fairly close together).
