My bad, the wrong cli and the attachment has been sent. Here is the corrected one attached. Also the cli was used:
../CuraEngine/build/Release/CuraEngine slice
-j ../CuraEngine/definitions/anycubic_mega_zero.def.json
-s cool_min_temperature=0 -s roofing_monotonic="true" -s roofing_layer_count=1 -s machine_nozzle_offset_y=0 -s machine_nozzle_offset_x=0 -s machine_extruder_cooling_fan_number=1 -s machine_extruder_start_code=
-g -e1 -o cube.gcode -l cube.stl
The gcode is attached too.
Slashee_the_Cow 276
Umm... you didn't actually include the bed temperature setting in the command you posted (and it's not in the output from CuraEngine).
