Posted
· Ultimaker S5 R2: test check models to print
Just print what you need to print. Everyone has completely different needs. You may need to print something smaller than a grape. Or bigger than a shoe. You may need something that doesn't need to look good but needs to be strong. Or you may be making artwork. Everyone cares about different things and every requirement requires making choices. e.g. you can print fast, accurate, or pretty but each one of these desires hurts the other 2.
So instead of thinking of this as a precious posession, think about what you need to print.
gr5 2,178
