Thanks a lot for the reply!
First point: Thanks for educating me - I simply used the default setting for .stl export from NX and wasn't aware. I changed the angular tolerance setting from 18° (default) to 2° and it looks much better. I also deleted the smallest channel from the testpiece. I think the curvature looks much smoother now.
I also changed every flow setting I could find to 100%. In fact, most of them were, only initial layer bottom flow and inner wall flow was at 95%. I disabled the experimental bridge setting (but the flow setting was also at 95%). This time I added the project file (sorry for that).
As you can see from the photo, the result has not really changed yet. While printing, I can see through the individual lines of the first layer covering the channels. Furthermore, the channel depth is has a depth of pretty accurately 1.3 mm which is exactly one layer less (0.1 mm) than the targetet 1.4 mm.
Slashee_the_Cow 620
If you could provide the Cura project file (.3mf, get it ready to print then go to File > Save Project) that would really help.
The line distance: I can say with 78% surety that your Flow setting (in the Material section) is way too low, at least for the top/bottom, but possibly all of them.
Slicing the model myself, this is 100% flow:
And this is 50% flow:
It also doesn't help that your circle is really not very circular.
By my count, it's... a tricontahexagon (or in non-smartarse language... has 36 sides).
It's so bad that when you're slicing it the width varies so much that for the inner circles (at least), it varies the number of lines to fill them (from your screenshot, highlights added):
replaced second screenshot to make it more clear
