There is! Place a support blocker, stretch it so that it comes into contact only with the top surfaces you want to iron (so in this case the block should start slightly below surface B, and end just above surface B and below surface A, make sure it also starts above surface C).
Go to "Per Model Settings" while having your block selected -> Modify settings for overlaps -> set it to "Cutting mesh" -> select settings -> look for "enable ironing" -> click "Enable Ironing".
If you require any specific ironing settings make sure to also tick those boxes as needed.
This *should* make it so that only the top surfaces within the "support blocker" area are being ironed.
Edit: corrected the letters
Edited by PizzaTijd
Slashee_the_Cow 267
I don't think there's a way to do this built into Cura. It could probably be done via a post-processing script.
For what it's worth, for top quality results with surfaces like this make sure Top/Bottom > Monotonic Top/Bottom Order and Top/Bottom > Monotonic Ironing Order are both turned on.
