Thank you for your reply and help, I went ahead and printed a previous model and moved it over the same area as where the problem was, and so far it is printing completely fine, so there must be something up with the print I was trying before hand that's not showing in slicer that my printer don't like, strange one
Slashee_the_Cow 270
If you try printing a file which has printed fine before and has a problem now, it's almost certainly something about the printer.
Make sure your belts are tensioned correctly and that the wheels on the Z-axis gantry are at the proper tightness (you should be able to put a couple of fingers on them and make them move back and forth a little, but not too much).
If the noise changes when it starts doing that second layer it could be something to do with not being able to move that gantry, although that doesn't explain the off lines on the bottom.
Worst case scenario: the motherboards in these things don't have a brilliant reputation for working as normal (or at all) for the reasonable life of a printer.
Also, these days, you usually don't need to use rafts: they harken back to the days when bed adhesion was a lot more of a problem (because half the time you didn't have a heated bed) so you did something big and solid which would much more easily adhere to the bed, then print your model which will easily adhere to the raft. But these days it's a lot easier to get things to adhere to the bed so they don't really need much help in that regard (or if they do, a brim should suffice).
